Laurel;
<"right click customization" is greyed out unless I check "short-cut menus in drawing area".>
This is the way it is supposed to work.
<If I change right-click customization for right-click to mean "enter" and "repeat last command" it unchooses "shortcut menus" but right-click brings up the shortcut menu in the drawing area anyway.>
This is NOT the way it is supposed to work!
As long as you select "Apply & Close" in the Right-click Customization window before exiting it should work correctly.
The fact that it does not work right probably means that there is some damage to the AutoCAD installation.
Can you please try resetting AutoCAD to defaults to see if that returns the correct functionality to the program?
How to reset AutoCAD to defaults
If you have any customizations, you will want to backup your settings first, then restore them after resetting AutoCAD to defaults.
BACKUP:
- START>All Programs>Autodesk>AutoCAD 2016>Migrate custom settings>Export AutoCAD 2016 settings. 2. Click the EXPORT button. 3. In the Export custom settings dialog box, select a location (like your desktop) to save the ZIP file created by the program.
This is the file that you would save to your desktop so you can access it later, or copy to a removable drive to move settings from one computer with AutoCAD 2016 to a different computer with AutoCAD 2016.
RESTORE: START>All Programs>Autodesk>AutoCAD 2016>Migrate custom settings>Import AutoCAD 2016 settings.
Point the program to the file you created previously.
Steve Tamplen
Technical Support Specialist
