If you want the outermost extents to be that size, it's easy enough, starting with SCALE and the Reference-size option, but since the proportions are not exactly that, questions arise --
If I make it 5 units long, it's 1.0365[ish] units wide. To make it 1 unit wide could be done by STRETCHing, but should the sides be Stretched in and the middle slot and hole stay as they are? Or should the slot be proportionally narrowed? Or should the widths of the side parts remain as they are, with the slot narrowed by the same amount as the overall width is? Should the circle [that isn't a Circle entity] remain circular, or be narrowed into an Ellipse? If it remains circular, should it be reduced in size by the same amount as the overall, or proportionally, or left at its current size? Etc., etc., etc.
Kent Cooper, AIA
