AutoCAD Forum
Resetting viewport line width?
4 REPLIES 4
798 Views, 4 Replies
Does anyone know how to change or reset the line width on a viewport?
I have a drawing that somebody was working in, I think they must have clipped the viewport to a polyline that had a width of .01 set to it or something, but now the viewport itself has that width set to it and it's obscuring some objects near the edge of the viewport.
I know I can reset it by deleting the clip and then reclipping it to a polyline with 0 width, but it would be nice to not have to go through that just to fix it. I can't seem to find out how to do it otherwise.
4 REPLIES 4
Patchy
Click on it, go to Properties and change lineweight, does it work?
in reply to: Patchy
Ahhh I just found it.
When you select the viewport, in the properties box it shows Viewport at the top for object type, but if you hit the drop down arrow it also has a Polyline there, and you can change the width of the polyline. Wish I'd seen that sooner!
dbroad
Since you are replying to Patchy's solution, he's the one who should have been given credit for the solution.  Right?
Architect, Registered NC, VA, SC, & GA.
in reply to: dbroad
Nothing against him but his answer didn't help, I found it on my own. It wasn't the lineweight but the line width.
AutoCAD Inside the Factory
