reset the ucs to original
Message 1 of 9
Hi I have a problem, every time when i worked on AutoCAD, my ucs will change like this
the origin changed, now its not (0,0,0), I want to reset it to (0,0,0), how to do this?
Thanks a lot
Accepted solutions (3)
Replies (8)
Message 2 of 9
Alfred.NESWADBA
The UCS can only change by itself when "dynamic UCS" is active, try to turn it off (using UCSDETECT or <F6> ... >>>details<<<)
(or you do have 3rd party apps installed, which might use UCS in it's application functionality)
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
imadHabash
>> I want to reset it to (0,0,0), how to do this? <<
you can do this while NAVCUBE is ON , select WCS .
Imad Habash
Message 4 of 9
SEANT61
This thread had a similar discussion:
https://forums.autodesk.com/t5/autocad-forum/help-origin-point-of-preset-orthographic-ucs-keeps-chan...
See if any of the info there helps.
May your cursor always snap to the location intended.
Message 5 of 9
thanks a lot, i guess currently the best way to fix this is to use custom ucs
Message 6 of 9
SEANT61
If the complexity of the drawing is fairly low (just geometry in ModelSpace),  a copy and paste into a new drawing is probably the most straight forward method to get the Orthographic Views re-coordinated with the WCS.
If not, follow the suggestion about creating new named UCSs.
In reference to some of the posts in that other thread; do you often use the PressPull command?
Message 7 of 9
yeah i use it a lot, and i am mostly use AutoCAD for 3D purpose (although i m aware that it is more suitable for 2d), like these kind of thing ...
Message 8 of 9
SEANT61
Indeed you do have an extreme level of detail going on there.  Try to make note if you run into the Orthographic View UCS problem again.  I suspect the problem results from UNDOing back through a PressPull command.  I was able to capture one occurrence of the problem here:
http://autode.sk/2AGQaxC
It is not an easy situation to replicate, however.
Message 9 of 9
JMGunnar
UCSDETECT IS SET TO 0
I have found that when selecting presspull from the 3d Modeling Workspace ribbon, the UCS doesn't change. If CTRL+SHIFT+E is used to trigger presspull, then it does cause the anomalous UCS.
Johan
