Reset font or font style in text styles.
Message 1 of 9
I am exporting from revit to dwg. When exporting it creates a lot of font styles applied to the appropriate fonts. The problem is that while the font itsself is correct, the font style is set to regular which produces a very light font that does not update by the layers lineweight. I've found that if I open the text style and reselect the font, then use ReGenALL, the fonts will then display correctly.
EX:
Before:
Text Style: Simplex_B
Font: Simplex.shx
Font Style: Regular
After:
Font: Simplex.shx
Font Style: blank
How can I fix this without changing it manually every time? There will normally be 10-20 fonts in each drawing, and I will have 10-50 drawings. I need a way to change this more effieciently.
Replies (8)
Message 2 of 9
I found project standards, and they do not work. The text styles are not consistent from one drawing to the next so project standards will just switch things up that shouldn't be.
Message 3 of 9
pendean
Community Legend
Community Legend
May I ask why you all concert REVIT files all the time to dwg?
Message 4 of 9
It is what the customer wants. Our preference is PDF's.
Message 5 of 9
pendean
Community Legend
Community Legend
Ah! You work in REVIT but ship as dwg files when PDF will not do.
I suggest you ask in the REVIT forum about tips to help you with that problem while you wait here: it's a REVIT quirk that I suspect REVIT experts over there might be able to address.
Message 6 of 9
I don't believe this is within my power to change via Revit. I have already explored all availiable export options revit contains. I am almost certain this is an problem that needs to be solved with autocad. Since it cannot be done with project standards I probably need a LISP routine or VBA code. Unfortunately I am unfamiliar with VBA and LISP. What I need is a LISP routing or something that takes the text styles and sets the font to the current count for that text style. I doubt it is particularly complex, and I'm looking in to LISP now to find what I need. Any help with this would be appriciated.
Message 7 of 9
Ok, after some more reading, the problem seems to be that revits TTF's are being mapped to simplex.SHX. This is what I want, but unfortulately after being mapped the font style is regular, rather than just being treated as a SHX font. This doesn't solve my problem, but at least I better understand the cause.
Message 8 of 9
RobDraw
Why not make your life easier and use the TTFs?
Rob
Message 9 of 9
This is a client requirement, and truetype gives me less control over appearance than shx.
I found a lisp routine elsewhere while searching last night:
(vl-load-com)
(defun c:updateTextstyles (/ new)
(setq new (strcat (getenv "systemroot") "\\Fonts\\Arial.ttf"))
(vlax-map-collection
(vla-get-textstyles
(vla-get-activedocument
(vlax-get-acad-object)))
'(lambda (x / font)
(setq font (strcase (vla-get-fontfile x)))
(if (wcmatch font "ROMANS.SHX,SIMPLEX.SHX,TXT.SHX")
(vla-put-fontfile x new)))
(princ)
Additionally it turns out that the font is actually stored in the style table as simplex.ttf but it for some reason it appears in the UI as simplex.shx.
