Requesting help with AUTOCAD 2016 Installation
After over a month of trying EVERY method recommended to me via email tech support I still am unable to install AUTOCAD 2016. I am being told it is an error with C++ 2008, however after doing the suggested ideas, namely completely removing all traces of C++ on my PC, I still can not install. Email tech support is no use on this matter, as all they do is send me the same copy/paste response over and over. Attached is my installation log (note the various dates) any help is appreciated. Thanks in advance.
GTVic
Line 131 shows which install fails. You can run this manually to see a better description. Try running as administer, by right-clicking the EXE file.
More help here: autocad-architecture-general/error-1603-installing-autodesk-autocad-architecture-2011
