Solved by Alfred.NESWADBA. Go to Solution.
by default the sunlights color is calculated by geographic position and date/time. It is the default that at the end of the day the sunlight get's more orange.
Changing the date/time will correct the value.
Here you can see two images, just the time changed between 1pm and 6pm, nothing else than time was changed.
- alfred -
- alfred -
