07:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created some simple line based objects and created blocks out of them with WBLOCK. The name scheme was 1.2m.pipe.pipex, 3.0m.right.angle.pipex (pipex suffix). I then used these individual component blocks to assemble some prefabricated larger assemblies such as Mezzanine.1.2x1.2m I later created 3D versions of the same individual components and WBLOCKED and named them them with the same suffix. At the same time I re WBLOCKED the original simple line based objects but this time named them 1.2.pipe.trueflex, 3.0m.right.angle.trueflex (trueflex suffix). Now when inserting either of the 3D blocks (pipex suffix) and the reblocked/renamed line based objects (trueflex suffix) from the tool palettes in a drawing there are no problems since the naming scheme for all are unique to each block. However, when I insert the prefabricated assembly blocks which were created with the original line based objects with the pipex suffix, I now have an issue where, once exploded, I then insert the 3D blocks of the same type, they are inserted as the line based objects that made up the assembly and not the true 3D objects that they now are which occupy the the same original name scheme. Unforeseen planning on my behalf. Other than recreating all the assemblies with the newly named line based objects (also want to do versions with the 3D blocks) is there a quick and dirty method to work around this conflicting scenario? I'm not sure REDEFINE or REFEDIT are suited to this. Is there a possibility to select inserted assembly block without exploding and obtain a list of all the individual block names and change and replace the suffix from pipex to trueflex? Ideas appreciated.
