Rename Layout to match "suffix" not prefix of sheet number
Eliasgalvan
Eliasgalvan
Hello All,
I am learning to use Sheet Set Manager. I would like to rename my Layouts adding the page number AFTER the Standard Layout Name. The only option I see available is to add BEFORE. Did anyone has ever run to this problem?
Thank you!
natasha.l
Hello @Eliasgalvan
The option during the creation of a sheet set seems like what you are looking for, when you select the "Import Options"... you receive the dialog below:
Also, take a look at How to Organize AutoCAD Sheets
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Eliasgalvan
Hello Natasha,
Thanks for your response. But I was looking for a way to add the sheet number after the Title. It seems AutoCAD only provides an option of adding before the title.
