03:04 AM
Is there a formatting option that will allow a field to return a value from an object as a rounded up number? For example. If I take the line length of a polyline as a field and the value returned is 892.2464mm is there any way to remove the trailing values (i.e to display 892mm with no decimal values following)
Example attached to the problem.
