Removing trailing numbers from object field values
No aplicable
Is there a formatting option that will allow a field to return a value from an object as a rounded up number? For example. If I take the line length of a polyline as a field and the value returned is 892.2464mm is there any way to remove the trailing values (i.e to display 892mm with no decimal values following)
Example attached to the problem.
0 Me gusta
Responder
Soluciones aceptadas (1)
455 Vistas
2 Respuestas
Respuestas (2)
imadHabash
Solución aceptada
it can be done when you right click your digit then Edit Field . follow below image to get what you need .
Imad Habash
0 Me gusta
No aplicable
Thanks!
