Removing multiple subfolders on sheet set manager
alxnds5
alxnds5
Hi everyone,
I'm wondering if there is a way to do a mass removal of subfolders in a sheet set? - when I go to remove them from my sheet set the removal option is greyed out, what can I do?
cheryl.buck
Autodesk Support
Autodesk Support
Hi @alxnds5,
Thank you for posting. It does seem to only allow removal of one at a time. Is the option grayed out when you select only one subfolder too?
All the best,
Cheryl Buck
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
JTBWorld
It can't be done in the Sheet Set Manager. With some XML knowledge you can use our JTB DST Tool and do it or we can do it as a service or create a solution for it.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
alxnds5
No it's not but I was looking to remove multiple in one shot since I have so many
cheryl.buck
Autodesk Support
Autodesk Support
Hi @alxnds5,
I can understand that. I am not aware of a way to select and remove multiple folders, but do think that would be a really useful feature.
It may be worth reaching out in the AutoCAD Customization forums to see if any members have written a script that automates the process. Also I encourage you to submit the idea to the Product Feedback team for future consideration.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
alxnds5
thank you! - i will do both
