AutoCAD Forum
Remove window/crossing window tooltip adjacent to crosshairs ?
2 REPLIES 2
db
927 Views, 2 Replies
Hi.... I have just upgraded to Autocad 2021 and have an annoying tooltip that appears adjacent to the cursor/crosshairs when I select a tool and then click in the dwg to start to move around.  The tooltip appears to be informing me what tool I am currently using (eg. move or copy etc) or similarly (window or crossing window symbol).  I don't need these annoying reminders of what tools I'm using because I selected the tool so I know what I'm doing.
Does anyone know how to get rid of this ?
Labels (1)
2 REPLIES 2
vinodkl
in reply to: db
Hi @db
Those are called Cursor Badge. You can turn them off by typing in the command "CURSORBADGE" and setting it to "2" 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
db
in reply to: vinodkl
Thanks vinodkl....
Cursorbadge was indeed the system variable.  I ended up having to set it to 1 to get rid of them.
AutoCAD Inside the Factory
