remove sheetset from DWG
jdfnnl
jdfnnl
I have a file that was modified and renamed but is still associated with the original sheetset. I have created a new sheetset renamed to match that of the new file, but the original sheetset still is the one that occurs in the SSM when the new file is opened. Is there any way to disassociate the old sheetset from the new file before creating a new sheetset?
JTBWorld
See https://blog.jtbworld.com/2005/10/remove-sheet-set-association-on-sheet.html
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
timothy_crouse
You can use utilities from JTB to manage sheetsets  OR in this simple case I think you would have to ensure you move the new dst and dwg file to a new file location.  But the relative path to the file would have to be identical.
Meaning if the original drawing was in a directory called XREFs off the main drawing directory then that is the path you need to set up in the new drawing directory.  If this relative path is not setup AND the dst database can find the original file it will grab it instead.
When I use an existing sheetset as a starter for a new project I typically copy the entire drawing tree to a new location then go into the sheet set manager and start removing drawings I do not need.
Keep in mind any Reference callouts placed into the drawing will always look for it the original drawing that is referenced in the link path.    To expand on this >> If you drop a reference to a sheet view and you then use that sheet in a new sheet set project that view ref will be pointing to the file in the original project.  This is where JTB tools are helpful  OR you relink as required.
I hope I help and my answer was not to confusing 🙂
Best Regards
-Tim C.
