remove multiple blocks above each other
Dears
I got a drawing form an architect which all lines and blocks are dulicated (3 or 4 times above each others) ..i used the overkill but i got no result...is thier any other option to delete the duplicated drawings?
nrz13
I don't have time to look at the drawing right now, but have you unchecked all boxes under the "Ignore object property" section when you run the OVERKILL command?
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
JTBWorld
Overkill does not recognize identical looking blocks with different names, etc.
You could explode all and then run overkill.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Well ...even if i checked all the boxes it would'nt delete the blocks
