& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Dears
Every time i use polar tracking i get the traking with angle 23....will this is not additional angle and i see in the increment angle only 22.5....how can get rid of this angle?
Hi @KMVHT
The angle shown as 23 is actually 22.5 but its showing as 23 is because the precision of the angle is set to zero. Try changing the precision from "UNITS" and see. Type in the command "UNITS" and change the angle precision🙂
When going to the settings of the polar tracking you can set the amount of degrees that you wish to use for the increment. The standard choices are :
90,180,270,...
45,90,135,...
30,60,...
22.5,45,....
etc..
You can also add your own number of increment.
As for the fact that 22,5 shows up as 23, it is as @vinodkl has mentioned, the value is applied correctly, but the properties will show it rounded up if the precision of your angular units is set to 0. If you wish to see it displayed correctly, you can increase the precision to several places after the comma.
That's solved the problem...thanks a lot
Thanks for your post
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
