Remove Hidden Data and Reduce File Size?
I have an AutoCAD 2010 DWG file that seems to contain hundreds of thousands of "hidden" or "invisible" objects resulting in a file size of almost 10MB.
The drawing is a simple 2d titleblock.
As a test, I erased all of the visible objects from both Paper Space and Model Space.
I then ran Purge and purged "everything" from the drawing file.
File size is still almost 10MB in size, even though there are no visible objects on the screen.
When I type "Status", I get "451210 objects in...".
"Paper space uses *Nothing*".
"Model space uses *Nothing*".
I had a colleague run Super Purge on the file, but file did not reduce in size.
I have manually rebuilt the titleblock from scratch, and the file size of this NEW file is only 84Kb.
Problem is, the OLD titleblock was used in dozens of drawing files.
(Copy/Paste or SaveAs typically used to create new drawings.)
All of these files now contain these mysterious "451210 objects...".
Rebuilding dozens of existing drawings from scratch is not really an option.
Besides, if I copy/paste ANY objects from an existing drawing file into a new file, the 451210 "hidden" objects always seem to come along with the selected objects.
Exporting the OLD titleblock as a DXF file actually INCREASED the file size.
As far as I know, the OLD titleblock drawing was originally created with "plain" AutoCAD, probably 2005, or possibly even earlier version.
No 3rd party software was involved in the creation of this titleblock as far as I know.
I've read some of the other posts in AutoCAD forums regarding deleting hidden data, but haven't found anything yet that might solve this problem.
Any suggestions/comments would be welcomed.
martinwk2
