Remove Block Reference
tsopha7ECZP
tsopha7ECZP
So, I had two blocks: block A and block B.
I copy and pasted block A into block B, then exploded the pasted Block A.  By doing this I hoped that it would get rid of the reference of Block A, and I would be able to purge Block A out of the file, but it still says Block A is nested inside of Block B.  How do I remove the reference from Block B so I can purge Block A? Sorry this is so confusing.
cadffm
>>"I copy and pasted block A into block B, then exploded the pasted Block A. "
>>"By doing this I hoped that it would get rid of the reference of Block A, and I would be able to purge Block A"
That should be the case, yes.
>>"but it still says Block A is nested inside of Block B."
Then it is.
>>"  How do I remove the reference from Block B so I can purge Block A? "
Go into BlockB (BEDIT BlockB), select the references and Erase them.
Bsave Bclose Purge
Share your File and we can check the issue without guessing.
Sebastian
tsopha7ECZP
Is there a way to locate the reference?
cadffm
All layers thawed and on
Use QSELECT and filter for the Blockreference NAME.
Doesn't work?
Share this file or another one:
Create a DWG with only one BlockB Reference inside and
share.
Sebastian
tsopha7ECZP
That's all I was looking for, thank you.
