Remove Bimcollab ribbon tab
harald_ebbers
Message 1 of 10
harald_ebbers
I have been searching on how to permanently remove this but no success.
Current status is that it is not there when I open autocad. But when I open any drawing the ribbon tab appears and focus is also shifted to this ribbon tab, so I will have to click on another tab again to start work.
I have already:
1 Uninstalled bimcollab from windows
2 Unticked both the ribbon tab and ribbon panel and resaved profile
3 Installed another version of autocad (but had to import settings from previous version as to not to lose them)
Anybody has a clue on how to permanently remove this?
Update:
See other topic for solution: https://forums.autodesk.com/t5/autocad-forum/automatic-command-after-opening-a-drawing-where-to-modi...
Replies (9)
Message 2 of 10
Valentin_CAD
@harald_ebbers ,
Try removing the APP:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 10
harald_ebbers
There was nothing in Contents button under Startup Suite.
I checked through the lsp files, but found nothing on bimcollab there.
Message 4 of 10
Valentin_CAD
@harald_ebbers ,
Emilio Valentin
Message 5 of 10
harald_ebbers
I could do that but then I would lose all the other modifications which I don't want.
Message 6 of 10
Valentin_CAD
@harald_ebbers ,
Remove the Bimcollab if shown in the CUI, then save or saveas - may even want to reopen.
Show us your sample:
@harald_ebbers wrote:
... Unticked both the ribbon tab and ribbon panel ...
Emilio Valentin
Message 7 of 10
harald_ebbers
That doesn't work, I don't see bimcollab in the CUI there. It is only added to the menu once I open any dwg file.
Message 8 of 10
Valentin_CAD
@harald_ebbers ,
Does it show up in the Windows add/remove menu?
Emilio Valentin
Message 9 of 10
harald_ebbers
Yeah, I did the uninstalling already.
I just now did a clean install of autocad 2024 without any migration. Once I opened a dwg, bimcollab was added to the menu again.
Message 10 of 10
Valentin_CAD
@harald_ebbers ,
Time to open a support ticket:
Emilio Valentin
