relative path length in Hyperlink
Martin-Winkler-Consulting
Advisor Advisor
I have a problem with the path length of relative paths in the hyperlink of a block.
If I enter here a path with 92 characters the jpg file is found and opened.
Path: .. \ .. \ .. \ .. \ .. \ AU-General Documents \ AL-General \ SYMB-Symbols \ 03-Images \ T12345678912.JPG
From 93 characters I get the error message:
"System could not find path"
Path: .. \ .. \ .. \ .. \ .. \ AU-General Documents \ AL-General \ SYMB-Symbols \ 03-Images \ T123456789123.JPG
The length of the file name does not matter. For example, if I change the character length of a folder and the total character length is below 93 characters, it also works again.
If I use absolute paths, I can use longer paths.
In this case, the associated absolute path is 170 characters long.
With a relative path length of more than 255 characters, I would understand that, but 92 characters !?
Does somebody has any idea?
AutoCad Mechanical 2019
relates to post in german Autodesk Forum:
https://forums.autodesk.com/t5/autocad-produktfamilie-deutsch/pfadlange-relativ-bei-hyperlink/td-p/9...
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
I've tested this with other paths. It doesn't seem to be the path length.
But I'm still a bit helpless why this path doesn't work at a certain length.
Are there any restrictions regarding special characters, spaces etc.?
I have already tried a few things.
Martin Winkler
CAD Developer
I've done some more testing and I can't understand why some paths work and others don't.
See screenshots
3DCS_Mittwoch, 11. Dezember 2019_14h01m20s_003_.jpg3DCS_Mittwoch, 11. Dezember 2019_14h00m35s_002_.jpg3DCS_Mittwoch, 11. Dezember 2019_14h12m54s_004_.jpg3DCS_Mittwoch, 11. Dezember 2019_14h18m04s_005_.jpg
Martin Winkler
CAD Developer
cadffm
Also wenn es sich auf der lokalen Festplatte auch so verhält und wenn du die die Chance auf potentielle Helfer vergrößern willst,
dann erstelle doch ein ETRANSMIT Paket,
achte auf die Übertragungseinstellungen Einstellungen (pfade beibehalten und alle Einfügeoptionen aktiviert).
Offenbar möchte niemand etwas nerviges und bereits exisierendes! für dich nachbasteln.
Ich würde testen..
Der Inhalt der Bilder und DWGs etc ist dabei wohl egal für den Test.
Sebastian
@cadffm
Diese Tests habe ich bereits durchgeführt auf 2 verschiedenen Rechnern.
Ich werde ein Beispiel erstellen. Ich hatte gehofft das es einen einfachen Hinweis gibt, das ich etwas übersehen habe.
Ansonsten habe ich den Fall auch schon an Autodesk eskaliert. @Volker.BRUNKE hat mir den Hinweis gegeben das er dieses Phänomen auch schon beobachtet hat und er es sich nicht erklären konnte.
I have already done these tests on 2 different computers.
I will create an example. I was hoping there would be a simple hint that I missed something.
Otherwise, I've already escalated the case to Autodesk. @Volker.BRUNKE gave me the hint that he had already observed this phenomenon and he couldn't explain it.
Martin Winkler
CAD Developer
The issue has been solved here
https://forums.autodesk.com/t5/autocad-produktfamilie-deutsch/pfadlange-relativ-bei-hyperlink/m-p/92...
Martin Winkler
CAD Developer
