Region fails to recognize closed areas
babysatch
babysatch
I encounter the following problem:
I have seven lines as you see in the figure below:
Running the command "Region" I expect to have 3 Regions, as this have been always the case until now. On smaller rectangular on the top, the bigger one below, and the biggest one enclosing the both.
I don't know what I'm doing wrong, but I get in this case just only one region.
Below you can find the dwg-file.
Could anybody give me a hint.
I would be very grateful.
Replies (7)
Vinayv4v
You can select all the objects and enter command region which will result in 3 regions as you mentioned. The problem with the drawing is end points are not merged. Try to edit using grip edit all the lines and merge to the end point and give it a try which would work fine.
But if you use BOUNDARY (Bo) command you will be able to create two boundaries which will not include the largest one consisting both.
See the screencast.
Cheers,
Vinay Vijayakumaran
babysatch
Dear @Vinayv4v,
thank you for your reply. This is part of a very big problem. Imagine I have thousands of such closed areas, clicking inside each closed area would be a little bit too much effort 😉
I always work with the funstion region. But in this special case, which I cannot understand, it doesn't work, and I would like to know why.
Vinayv4v
Here is the reason why you are getting one region other than 3.
Cheers,
Vinay Vijayakumaran
babysatch
...by the way I have uploaded another dwg-file. Region recognizes 3 regions in this file.
Thank you again.
imadHabash
i think that the problem exist at the lower right corner (see below image).i use FILLET command for this area then I've got 3 regions.
Hope it's help..
Imad Habash
babysatch
Dear @Vinayv4v
now I've watched your screencast. Did you mean by that, that there is a tiny little gap in my drawing, which you close by seperating ends of the lines and connecting them by the snap function?
Thank you!
Vinayv4v
Yes as in the picture posted by Mr. Imad one line is not joined correctly. That was the problem why you were not able to create 3 regions.
Cheers,
Vinay Vijayakumaran
