REGENAUTO COMMAND
Hi, I have a problem with the REGENAUTO command. In the old versions of Autocad, Autodesk explains that when this tool is off and you perform an action that requires regeneration, and the action is irrevocable (like layer reuse), the program says: "Regeneration is on hold". Well, I don't understand why layer reuse is an irrevocable action.... Here is autodesk's explanation : " Controls the automatic regeneration of a drawing. Obsolete The REGENAUTO command has been removed from the product. The following prompts are displayed. Enabled Regenerates the drawing immediately if there is any queued regeneration and continues to regenerate automatically whenever an action requiring regeneration is executed. Disabled Inhibits the regeneration of a drawing until the REGEN or REGENT commands are used, or REGENAUTO is activated. If you perform an action that requires regeneration and it is an irrevocable action (e.g. layer reuse), the following message appears: Regeneration is waiting. If you perform an action that requires regeneration and that action is revocable, the following message appears: Regeneration required -- continue? If you click OK, the drawing will be regenerated. If you click Cancel, the last action will be cancelled and the drawing will not be regenerated." I would also like to know what is an example of a revocable action? I understand by revocable that it can be cancelled, so I associate it with the undo command. Starting from this premise, the undo command works for any action, that's why I don't understand when you say that layer reuse is an irrevocable action. For me all the actions in AutoCAD are revocable..... I would be very grateful if someone could solve this doubt about why the reuse of layers in AutoCAD is an irrevocable action, and an example of revocable action? Thank you very much
Translated with www.DeepL.com/Translator (free version)
@Alfred.NESWADBA @imadHabash @ВeekeeCZ @pendean @Kent1Cooper
