AutoCAD Forum
Regarding:Template Alignment
0 REPLIES 0
Message 1 of 1
170 Views, 0 Replies
I updated Title Block Attributes Via C# in Autocad Interop method,
The Problem I m Facing is the Value updating Properly in the Below Template,but Text alignment is not Properly fitting its Overlapping or Starting from the middle.I also checked the Tempalte,Its in Middle Centre Only.While I m doing Manually its Properly aligning,but via code its not in Proper Format.
In below Tempalte U can See TEST TITle TEst is starting From Middle.TitleBlock.PNG
0 REPLIES 0
Technology Administrators
