Reference files could not be located or read
I was sent a file to open in AutoCAD and I get this error message:
"One or more reference files could not be located or read. What do you want to do?"
Is the file corrupt? What's wrong here?
cadffm
We do not have the file [UPLOAD], we don't know your software product and version[command ABOUT], how should we know?
Please remember, others can not see your monitor, all the information you need to give in writing
so we can work with the information. Smiley Happy
Try to open the file by using command RECOVER or if you don't use 2019,
use DWGconvert, part of DWGtrueview to convert the file to another format version.
if file = dwg2018
and your version = 2013-2017
then = convert to dwg2013
 :EDIT:
If you only got one file and AutoCAD informs you about a missing reference, then you are missing one or more files.
When you open the file, open the external references palette. Please share a screenshot showing all information.
Sebastian
That must have been it- they need to send more files! Makes sense. Thank you Sebastian!
cadffm
If the working with autocad, they should use command ETRANSMIT with all options
for xref fonts plotstyles ans so on..
Sebastian
pls guide how to solve it
