Reducing AutoCAD file size from MB to KB
Message 1 of 11
Hi Everyone,
I am trying converting AutoCAD mechanical .DWG file from 10MB to 700 kb in .DWG format.I tried dxfout,purge,wblock but nothing worked to reduce it to KB.Can I request Autocad expertsto help me or suggest suitable method to do this..pls help.
Accepted solutions (4)
Replies (10)
Message 2 of 11
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I suggest starting with an EXPORTTOAUTOCAD. Write to a new file. Then use Audit, Purge, -Purge>All, -Purge>Regapps.
Does that get you closer?
John Vellek
Message 3 of 11
imadHabash
Hi and Welcome to AUtoDesk Forum,
>> but nothing worked to reduce it to KB.<<
NOBODY said that it will.we can reduce fie size depending on the data that the CAD file have.some times purge and audit will not help but if you delete or mange a sophisticated block existing some where in the file it will help a lot.so what i want to say that your CAD file status and history will tell us how far can can we reduce it's size.
Imad Habash
Message 4 of 11
rkmcswain
Presuming the file should be 700k in size, you're probably suffering from one of the big three infections....
Scale List Entries
Regapps
DGN Linetype Data
Do you know about these things?
What version of AutoCAD are you using?
Do you have all of the updates and patches applied?
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 11
 Hi Gents, Thanks for your feedback.I am using Acad 2013 & tried also to reduce file size on Acad 2012.But no success till now.I am OK to share the file,if someone would give it a try.Please share your email id.Thanks!!
Scale List Entries
Regapps
DGN Linetype Data
Message 6 of 11
How to check CAD file status and history??
Message 7 of 11
pendean
Community Legend
Community Legend
Message 8 of 11
try...
dxfout - save the file
dxfin - open the file
save - to dwg (close the original first or make new file name)
audit > y - the most important step..
it works for me...
cheers
Message 9 of 11
thanks...it works
Message 10 of 11
Thank you sir, I have searched a lot of blogs and videos. I finally found the answer here. Thank you sir, you are a saviour
Message 11 of 11
THANK YOU
