Reduce Polyline points
Message 1 of 28
I realize there are many posts about this but they all seem to be old and none of them are working for me.
I am running AutoCAD 2019 fully up to date. I have attached a sample file.
The program I use to convert a raster file to vector works very well at created an accurate conversion. Unfortunately this seems to mean that it creates a TON of nodes.
If someone knows a way to reduce the amount of vertices in the polylines, I am all ears!
Sandro
Replies (27)
Message 21 of 28
tomislav_vargek
does anyone has anything faster, even when I make vlx out of it it is still too slow because I have contour lines with milions of vertices to reduce and it takes half an hour to calculate!
Message 22 of 28
Kent1Cooper
@tomislav_vargek wrote:
does anyone has anything faster....
I couldn't say whether it will be faster, but you could at least try converting to "heavy" Polylines and using the WEED command >here<.  It was the source of the idea for PLDIET, but works only with "heavy" Polylines [PLDIET was written to work with "lightweight" Polylines].  Since it uses basically the same criteria to decide whether to remove a vertex, it may not help, but just in case there's some difference in the way the two varieties respond....
Kent Cooper, AIA
Message 23 of 28
tomislav_vargek
thank you, I have first weed.lsp but it doesn't work, and this second weed2.lsp that u Kent posted works really great and fast!!
Message 24 of 28
tomislav_vargek
the weed2 that u posted fits my needs perfectly and this one could be of use too.
thank u both for quick replies!
Message 25 of 28
njfaulhaber
Community Visitor
Community Visitor
Cadalyst's website and the link are now down.  Does anyone have another source for the polyline .lsp?
Message 26 of 28
tomislav_vargek
here u go
Message 27 of 28
TomBeauford
For those using any of the Map 3D verticals Weed Polylines does a nice job.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 28 of 28
Kent1Cooper
Here's a newer version of PLDiet.lsp.  [I don't recall what changed from the earlier version(s), if anything beyond what the comments at the top describe differently.]
Kent Cooper, AIA
