Rectangle question
Rectangle question
Rectangle question
Hi I want to create a rectangle where I know one length but want to adjust the other length manually for instance...
I know one side of the rectangle should be 1/16"
But the other side I want to stretch a snap to a wall or other line maybe, if I don't know exact distance.
I feel like I should be able to do this but I am not seeing how to do this.
Kent1Cooper
Point Coordinate Filters are probably the way to go.
If you want to draw a Rectangle that's 1/16" wide  [from left to right], with the height  to be determined by some kind of locational selection, start RECTANG and give it a corner, then:
.X
with the preceding period/decimal, and when it says "of" give it a point 1/16" to the right [or left with a negative]:
@1/16,0
and when it says "(need Y):" select whatever location is to determine the vertical position of the other end [whether above or below].
If you want it 1/16" high, with the width  to be determined, use the .Y point filter and give it the 1/16 as the Y coordinate of the relative point instead:
.Y
@0,1/16
Kent Cooper, AIA
GrantsPirate
Start the RECTANGLE command, pick the start point, hit D for dimensions, type in 1/16, next type @ and enter, then pick the wall where you want it to end.  This will be for the X to be 1/16, for Y to be 1/16 you mix the above up just a little.  Start RECTANGLE, pick start point, hit D for dimensions, type @ enter, pick where the length for X would be, then 1/16 for the Y dimension....
Personally I would just make a rectangle 1/16" x 1/16" and then grip stretch into place.  I think that is actually quicker.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Okay so I am not crazy in thinking that there was not a way to do that easily. Thanks for the help
