layer check question
layer check.JPGI want to find which layer a line is on. The line is in the xref of a xref file named "bp". See check result in the picture, I want to find which layer it is on, it should be something like bp | xref | parking_001.
what settings should I change?
Kent1Cooper
Nested-entity selection can tell you that:
(cdr (assoc 8 (entget (car (nentsel "\nSelect object for its Layer name: ")))))
[It will also report on a non-nested object.]
Kent Cooper, AIA
GrantsPirate
Use the XLIST command.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
