Rectangle getting joined automatically
When ever I place 2 rectangles or lines next to each other, they join automatically and I am unable to move it separately. It deletes separately but doesn't move.
pendean
Community Legend
Community Legend
Really? Using what commands exactly? And what variant of AutoCAD are you using?
Doesn't move? Is your UCS rotated but your PLAN setting does not match the current uCS perhaps?
Post a sample DWG file with these self-gluing RECTANG objects that o not move separately but erase separately for review here please.
imadHabash
would you please make a screencast to see what exactly happen with you ?
Imad Habash
cadffm
Without a DWG sample or a Screencast, hard to say, but i guess:
IF i am right:
Learn more about Geometric Constraints! [F1]
About Geometric Constraints
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-668B1B7D-9991-44CA-8607-83665A82FF7F
Commands for Geometric Constraints
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-18D95297-BCB0-40FB-943D-0EE94528F24C
For you the most important setting for now is: AUTOCONSTRAIN (Command)
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-2E53F0A6-640C-4B3A-A650-18F1A5F781E1
DISable this feature
And then read about DELCONSTRAINT (Command)
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-E47B6F79-C7DA-45ED-AFA6-6C0945DB6375
all about
http://help.autodesk.com/view/ACD/2021/ENU/?query=Geometric%20Constraints
Sebastian
Kent1Cooper
Do you have inferred constraints turned on?
If that's somehow locking them to each other, you can remove the constraints with the DELCONSTRAINT command.
Kent Cooper, AIA
