Message 1 of 12
Is it possible to manually enter the first input of a rectangle, and then select a snap point for the second dimension. As you can see below I started a rectangle at the top left corner of the existing rectangle. I then entered 0.75" for the width of the rectangle. Then I hit Tab and I wanted to snap to the bottom corner of the existing rectangle. It shows that I selected the endpoint, but you can see it doesn't work. What am I missing here?
