Recover a .dwg file in a zipped folder
Message 1 of 11
Hello everyone!
I was working on a .dwg file that I opened from a zipped folder. Thinking I had extract the file, I saved it and then closed it. Now I lost all the changes I made and I wonder if there is a way I can not re-do all the work!
Replies (10)
Message 2 of 11
Alfred.NESWADBA
wow, never tried this and never had this issue that if you save a dwg it is not saved.
First important thing is, when opening a dwg from inside a ZIP I get these infos shown:
So the info about locked/readonly gets displayed twice!
When you then close the dwg after you modified something you should see this:
Did all this not show up on your system?
I guess best you can do is to search through your complete hard-disk (include hidden folders) for files of type
  • DWG
  • BAK
  • SV$
which were modified in the last few minutes and see if the search comes up with valid files.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
Thank you very much Alfred. Actually neither of the messages was shown. Strange! Are there any efficient ways to search for the recent dwg bak and svg files?
Message 4 of 11
pendean
Community Legend
Community Legend
Did you open the ZIP file in a cloud file server?
WindowsOS or MacOS or something else?
Sadly, your edits/changes in that DWG file are gone forever if you cannot find an SV$ or BAK file to rename in your OS's login temp folder.
Message 5 of 11
Alfred.NESWADBA
Sorry first ... "SVG" was a typo, should be "SV$" (have corrected this already in my previous message).
There are a lot of tools in www for searching the harddisk, at least you can use Windows Explorer (>>>click<<<).
- alfred -
Alfred NESWADBA
Message 6 of 11
Today I had an identical problem. I wonder if you were able to recover the lost files and if so, how??
Message 8 of 11
Hello!
Sadly, I couldn't locate the files even in the Temp folders. I redid the work. Did you try some of the methods suggested in this thread?
Message 9 of 11
Yes, I tried everything, but unsuccessfully.. at least I learned not to keep files in a zipped folder anymore
Message 10 of 11
pendean
Community Legend
Community Legend
>>>...at least I learned not to keep files in a zipped folder anymore...<<<
Excellent advice for all of us.
Message 11 of 11
Yes, I will keep it in mind too! 😅
