Recomendations for a New Monitor
Message 1 of 23
I am working with AutoCAD 2016. I currently have a 24 inch Dell2407WFP 1920 x 1200 pixels. 59.95 Hz. I want to have multiple applications open eg a spreedsheet and my AutoCAD drawing and so am looking to purchase another monitor around the 27-29 inch size that I will use for my drawing and which will allow me a little more screen space. Current graphics card is Quadro 400. Does anyone have any recomendations as to monitors that could work for me or if not specific models, minumum specifications such as resolution......
Replies (22)
Message 2 of 23
parkr4st
any of the uhd monoitors such as samsung U28E590D on the display port will work good IMHO.
dave
Message 3 of 23
TerryDotson
We've used the "Dell UltraSharp U3014 30-Inch" for years with great results.  It's 2560x1600 so it's not designed for watching movies (perfect).
Message 4 of 23
HP Envy32 2560x1440
Message 5 of 23
wispoxy
Just get a 75" Samsung touch screen monitor. Easy to do graphic arts with, and you can also use it for TV, music, apps, and house controls such as lighting / garage / fridge / surveillance / pool / coffee / etc...
Message 6 of 23
steve216586
I can first hand recommend any 32" 1080p 120Hz, smart TV will be well worth looking into. They're not expensive, range from  $200-$300.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 7 of 23
pendean
Community Legend
Community Legend
Keeping in mind that AutoCAD is not designed for 2k or higher displays (look it up, they say so), 1920x1200 is decent on a 27" (my settings), so higher if you go 29" if you actually want more screen real-estate and not just bigger icons/text.
Message 8 of 23
pendean
Community Legend
Community Legend
IMHO 1080p is fine for computer (not TV) screens up to 24", beyond that 1080p starts to look like a monitor for those with bad eyesight needing large icons and text instead of investing in quality prescription visionwear 🙂
Message 9 of 23
pendean, do you mind me asking what brand and model you are using?
Message 10 of 23
kasperwuyts
I agree with Pendean on the monitor size issue. If I had known three years ago, I wouldn't have gone for a cheap 27" 1080p monitor as a side monitor for my laptop, and have bought a 24" one instead.
If it's any help, I'm quite satisfied with my 23" HP ZR2330w at work.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
Message 11 of 23
My opinion is to have identically sized monitors/resolution. Also, does your Quadro card have all the bells and whistles to create multiple desktops? Using that feature can unclutter a busy screen.
Message 12 of 23
wispoxy
Never did say my recommendation was good for AutoCAD. But It's fun with Adobe Illustrator, I can draw life size characters right in front of me. Activision Blizzard Inc has a 75" Samsung Touch Screen too for graphic arts.
Message 13 of 23
I agree that you need to avoid anything over 24" if you are only using 1920 x 1080. I bought a 27" 1920 x 1080 and although the big screen was nice, the resolution is way too low and everything looks jagged. Circles and arcs in ACAD look horrible. So I returned it and went for a 27" at 2560 x 1440 and it's perfect. Everything is razor sharp, but you do have to either accept smaller icons or take the time to play with some windows settings under "Windows color and appearance". I tweaked some of those settings and it worked out perfect.
Message 14 of 23
zaidshakir82
Dear
Did the rate (1920x1080) good for running AutoCAD Civil 3D 2017 on monitor size 25"
Model HP 25es Display http://support.hp.com/us-en/document/c05078309
OS: Windows 10 Pro 64
Message 15 of 23
I am looking for a new monitor but not really a wide screen. I would like to get a 32" like the taller rectangular ones we used to use-that matches the 30 x 42 format of most common drawings I use. I have a Dell 24" currently that I will use for all my other programs like excel and and outlook. Any ideas on a good one that will not break the bank?
Pat
Message 16 of 23
pendean
Community Legend
Community Legend
Why don't you find 2-3 units you like and can afford, come back and ask for a review by someone instead.
Message 17 of 23
Message 18 of 23
I am going looking this weekend, I thought if someone had a suggestion it might be helpful.
Message 19 of 23
gotphish001
As suggested above. If you plan on doing a dual monitor set up with your original monitor that you mentioned, your best bet is to get the same size and resolution as your current monitor. That should narrow choices down some for you. Even the same monitor if you can still get it and you like it. If you want that screen ratio and not a wide screen there are probably limited choices anyway too.
If I had to make a suggestion as per a specific monitor, I'd probably just say to stay away from brands/manufacturers that you never heard of. Stick to the standards, dell, sony, asus, acer, etc...things you recognize the the company name.
Nick DiPietro
Cad Manager/Monkey
Message 20 of 23
May be you can help me with a monitor issue.  I was running AutoCAD 2018 on Windows 7 pro 64 bit with a 22" viewsonic monitor 1600 x 1200 resolution was my choice & everything looked & ran great but now I upgraded to Windows 10 pro 64 bit & a new Samsung 24" monitor but now when I open a AutoCAD dwg, the drawing is centered within AutoCAD & will not open to utilize the entire drawing area within AutoCAD, I have tried changing all resolutions, settings etc., & nothing solves this issue, if I hook up my old 22" monitor to the windows 10 computer it works perfectly fine, it's only when I hook up the 24" monitor, all the programs open fine even AutoCAD opens full screen but as soon as I open the drawing & zoom all the drawing seems to squish up & go to the center of the screen, kind of reminds me of how cable tv will do that when certain shows come on & they go to a square box in the center of the tv & leave black bars on both sides of the screen, that's what happens to my drawings when I open them but only on the 24" monitor. Any ideas?
Windows 10 Pro 64 bit
AutoCAD 2018
Samsung 24" monitor
Intel I7 7th. gen. 4.2 ghz
Nvidia GDDR5 Video card
16 gig 3300 RAM
Andy
