random point boundry
ellbaz73
ellbaz73
hi
i have a region of random points as block
need to draw a polyline boundry to the region
how can i do
thnks
imadHabash
can you show us a screenshot for your issue please ?
Imad Habash
ellbaz73
SCREENSHOT
imadHabash
>> i have a region of random points as block ,need to draw a polyline boundry to the region ,how can i do
to connect those points with a polyline you may need to :
  • if those points marks are a point style you may need to select Node from Object Snap and start draw a polyline .
  • OR you have to copy the coordinates to a script file .scr then by SCRIPT command you can draw automatically.
Q: are you have too many points or just a little and as shown in your image ?
Imad Habash
ellbaz73
THAT MEANS NO WAY TO DRAW IT AUTOMATICALLY
LARG  NUMBER OF POINTS MANUALLY IS ILLOGIC
THNKS
Alfred.NESWADBA
If you have Civil 3D you might create a surface from these points, the surface has then a boundary you can extract.
But take care ... what is the upper part of the outline you are looking for? Left or right or something between?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
