random lines shows up on print only
Amalie_overgaard
Message 1 of 12
Amalie_overgaard
Hi when physical printing a pdf drawing from autocad random lines showing up across the print. im using AutoCad 2023. i've attached a picture of the problem. Im using plotter DWG to PDF. When printing the line shows up on all pages except of one row.
Replies (11)
Message 2 of 12
dmfrazier
Do you mean the lines do not appear on the PDF file when you view it, but they do appear on a hardcopy print from the PDF file?
If so, then perhaps the hardcopy printer needs servicing/maintenance.
Message 3 of 12
Amalie_overgaard
It only appears on the hardcore print. The printer is fine.
Message 4 of 12
dmfrazier
"The printer is fine."
How do you know this?
Do these random lines only occur when printing PDFs from AutoCAD DWGs? (Do you make hardcopy print of PDFs from any other applications?)
Still, I would recommend running it through any maintenance procedure it offers, if for no other reason than to rule it out.
Is this an ink-jet or a laser/toner type printer?
Do those "random" lines correspond to any geometry in the DWG? (Maybe lines or edges that are supposed to be hidden? Of course, it seems rather unlikely that such an object would be invisible on the PDF yet be visible when printed to a hardcopy printer.)
Can you try changing the PDF quality (resolution) settings to see if this makes any difference?
Can you post a copy of a PDF that does this for you, so maybe we can try to duplicate the problem with our printers, or perhaps see something in the PDF that explains it?
Message 5 of 12
Amalie_overgaard
Its an ink-jet printer from canon 1x6850. i've attached the pdf file and a picture of the issue. You can see a gray line appear along the edge and across on the that paper only. stopping in the next paper.
Message 6 of 12
paullimapa
what's the program you are using to send the pdf to the printer?
Paul Li
IT Specialist
@The Office
Message 7 of 12
Amalie_overgaard
Adobe reader
Message 8 of 12
dmfrazier
What are you using to open the PDF for printing?
I used Foxit Reader and then Adobe Acrobat Reader to open and print your PDF to a Brother inkjet printer. Both printed with no random lines that I could detect.
Assuming it is not a printer problem, one other thing I can suggest is to make a minor change in the print settings. For my printer, it was in Advanced settings:
Message 9 of 12
paullimapa
try using a different pdf viewer to send the pdf to the printer
Paul Li
IT Specialist
@The Office
Message 10 of 12
Amalie_overgaard
We download foxit and it worked but do you know how you set it to save inc?
Message 11 of 12
dmfrazier
Ink save setting would be in the hardcopy printer settings.
Message 12 of 12
john.uhden
@Amalie_overgaard ,
I love your name, but
Might the lines be color 255 (so you can't necessarily see them), but color 255 is set to a dark color?
Do they show up in a plot preview?
John F. Uhden
