"Warning: An error occured during save" when copying to clipboard
- Mute
- Permalink
- Report
I get this error every time I use the Ctrl+C or Ctrl+Shift+C or Ctrl+X combo.
The full error is:
"Warning: An error occured during save.
We recommend that you run RECOVER on the drawing."[sic]
Running recover on the file does not fix the issue, nor does AUDIT. I have the Autodesk Desktop App running and my software has "no updates available". This message seems benign as I'm able to paste whatever I copied after closing out of the warning message. It just adds an annoying step to an action I perform dozens if not hundreds of times per day.
This issue did not exist before I updated from stock to what ever was available as of yesterday, however, the issue then was AutoCAD crashing frequently. The issue mentioned above is preferred to constant crashes so I will deal with it in the meantime.
