"Unknown command" when running script
Hi everyone,
Apologies if this is trivial but I've been having an issue when trying to run a .scr file in AutoCAD. In order to draw an accurate quadratic curve, I have created a table of data points with a column C of ',' between x and y columns A and B respectively as suggested by the Autodesk site. x values range from 0 to 5 in increments of 0.1 and y values are simply x^2. I saved the file as .txt then converted to .scr but when running the SCRIPT command on CAD and selecting this .scr file, an error appears stating 'Unknown command "0"' which may be in reference to the first x value (which is also the first piece of data in the script). I followed the instructions provided by "Draw polylines defined by equations" from Autodesk Knowledge but something must be wrong/missing here surely? I've attached the .txt file if you wish to have a look.
Would appreciate any help on this matter greatly!
P.S. I'm planning on revolving this curve by 360 degrees to create a 3D bowl-like structure in case any method  for solving the problem above would be better suited for my next steps.
Thanks!
john.vellek
Hi @Anonymous,
Pleasee try my version of your file to see if it helps.
This is what I get when I run it:
John Vellek
Thanks for the speedy response John, the 'Pline' did the trick!
Kent1Cooper
You don't need to generate that series of points yourself as an external file if you don't want to.  You can use PolynomialFunction.lsp, available >>here<<, to draw the curve for you directly inside AutoCAD.  See the description there and comments in the file.
Kent Cooper, AIA
Hi @Kent1Cooper,
Wow, thanks for this. I've never used the LISP functionality before but this was really straightforward and actually a god-send for what I'm currently working on (and you must have put a lot of work into that code) so much appreciated!
Kent1Cooper
You're welcome!  It's good to know people are still finding a use for it.
Kent Cooper, AIA
