"Tangent Direction" option missing in Path Array
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Hello, I am going to use the Tangent Direction option in the ARRAYPATH command, but I can't find the option at the ribbon bar after I created an path array...
imadHabash
That's right .. you won't see this option after creating the array ( Array tab ribbon name ) . it's only appear while creating and with Array Creation tab ribbon name .
Imad Habash
kakarlapuneetha002
Community Visitor
Community Visitor
hey, currently having issue with the same. Did u happen to find the proper solution? Gonna be very thankful
