"FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at 6551335"
Message 1 of 8
the error at start-up of AutoCAD
"FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at 6551335" to random files in  AutoCAD 2013
Replies (7)
Message 2 of 8
Slawomir_
Hi itsbama and welcome at forums.autodesk.co
is it plain AutoCAD or other software built on AutoCAD?
Message 3 of 8
plain AutoCAD
Message 4 of 8
Slawomir_
Seems like video acceleration issue. Perhaps upgrading graphics driver will help. This instruction may lead you to solution.
Message 5 of 8
john.vellek
Hi @Anonymous,
This error message typically indicates that the graphics driver is having errors.  What hardware is installed on your computer? Have you checked for a more current driver than the one installed currently?"
Does turning off hardware acceleration in GRAPHICSCONFIG make any difference?
John Vellek
Message 6 of 8
Slawomir_
Hi, has the problem been solved?
Message 7 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
John Vellek
Message 8 of 8
I had same issue. When I tried to edit the measurement AutoCad crashed. The problem was that multiscreen setup was configured with "sourround spanning options" (Nvidia Driver Option) enabled. Disabling  that option AutoCad didn't crash anymore.
