Hi Alfred,
I checked my CUI.
In 2018: the right panel is empty (in the left panel: there is no subdirectory by Hatch Creation)
[cid:
[email protected]]
In 2017: the right panel show some properties from the Hatch Creation Contextual Tab (for instance contextual Display Type = Full with Focus)
[cid:
[email protected]]
I also tried a workspace-transfer from 2017 to 2018, but I can't get a Contextual Tab-directory under "Hatch Creation".
Timmy
Hi timmy,
Alfred.NESWADBA (Consultant) posted a new reply in AutoCAD Forum on 09-06-2017 09:23 AM .
________________________________
Re: "Contextual Tab State" Hatch creation
if you did a default installation nothing should have changed.
When you start command _HATCH in AutoCAD 2018 (and you don't have ribbons disabled) you should get the full hatch ribbon display.
One way to disable the ribbon switching to the hatch-creation tab would be to modify the CUI. So let's see how your state is when you start command _CUI, on the left side in the tree go to ACAD ==> Ribbon ==> Contextual Tab States ==> Hatch Creation (be careful, there are more hatch.... items).
Now how is the "Contextual Display Type" set on the right side?
If it's not set to "Full with focus" ... then change it to "Full with focus"
HTH, - alfred -
