the issue itself is depending on operating system and graphic card. >>>search results<<<.
I don't think it's something specific to AutoCAD.
So let me ask some questions:
- alfred -
Hi.
I have a similar problem only with Autocad LT 2010 (upgraded with the last service pack)) on Windows 10 (last upgrade). The problem appears only when switch trough differents drawings with the comand "Disegni vista rapida" on the bottom right.
The error detail is:
L'applicazione non supporta il debug JIT.
Ulteriori informazioni sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.Runtime.InteropServices.ExternalException: Errore generico in GDI+.
in System.Drawing.Image.FromHbitmap(IntPtr hbitmap, IntPtr hpalette)
in System.Drawing.Image.FromHbitmap(IntPtr hbitmap)
in Autodesk.AutoCAD.Runtime.Marshaler.BitmapInfoToBitmap(IntPtr bitmapInfo)
in Autodesk.AutoCAD.Internal.LayoutThumbnailEnumerator.get_Thumbnail()
in Autodesk.AutoCAD.Ribbon.QuickViewManagerUtility.UpdateQVDataForLayoutImages(List`1 qvLayoutList, LayoutThumbnailEnumerator eThumbnail)
in Autodesk.AutoCAD.Ribbon.DocumentsQuickViewDataManager.RefreshLayoutData()
in Autodesk.AutoCAD.Ribbon.DocumentsQuickViewManager.AcadApplication_Idle(Object sender, EventArgs e)
in System.EventHandler.Invoke(Object sender, EventArgs e)
in Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1)
in Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Assembly caricati **************
mscorlib
Versione assembly: 2.0.0.0
Versione Win32: 2.0.50727.8670 (QFE.050727-8600)
Base di codice: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
acdbmgd
Versione assembly: 18.0.0.0
Versione Win32: 18.0.309.0.0
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcdbMgd.DLL
msvcm90
Versione assembly: 9.0.30729.9177
Versione Win32: 9.00.30729.9177
Base di codice: file:///C:/WINDOWS/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3/msvcm90.dll
PresentationFramework
Versione assembly: 3.0.0.0
Versione Win32: 3.0.6920.8693 built by: QFE
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
PresentationCore
Base di codice: file:///C:/WINDOWS/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Drawing
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationCore.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationCore.resources/3.0.0.0_it_31bf3856ad364e35/PresentationCore.resources.dll
mscorlib.resources
AdWindowsInterop
Versione assembly: 0.0.0.0
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AdWindowsInterop.DLL
AdWindows
Versione assembly: 2.1.0.0
Versione Win32: 2.1.123.309
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AdWindows.DLL
AdWindows.resources
Versione Win32: 18.0.55.0.0
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/it-IT/AdWindows.resources.DLL
acmgd
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/acmgd.DLL
System.Configuration
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcWindows.DLL
System.Core
Versione assembly: 3.5.0.0
Versione Win32: 3.5.30729.8693 built by: QFE
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
AcWindows.resources
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/it-IT/AcWindows.resources.DLL
AcCui
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcCui.DLL
AcTaskDialogs
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcTaskDialogs.DLL
AcTaskDialogs.resources
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/it-IT/AcTaskDialogs.resources.DLL
System.Windows.Forms
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework.Aero
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
PresentationFramework.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.resources/3.0.0.0_it_31bf3856ad364e35/PresentationFramework.resources.dll
ContextualTabSelectorRules
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcWindows.dll
ManagedMC3
Versione assembly: 2.20.0.0
Versione Win32: 3.14.1
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/ManagedMC3.DLL
UIAutomationProvider
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcLayer
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcLayer.DLL
AcLayer.resources
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/it-IT/AcLayer.resources.DLL
System.Web.Services
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
WindowsFormsIntegration
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsFormsIntegration/3.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
7osyhg2u
System.XML.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml.resources/2.0.0.0_it_b77a5c561934e089/System.Xml.resources.dll
System.Web.Services.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services.resources/2.0.0.0_it_b03f5f7f11d50a3a/System.Web.Services.resources.dll
Accessibility
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcCommandToolTips
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcCommandToolTips.DLL
AcCommandTooltips.resources
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/it-IT/AcCommandToolTips.resources.DLL
AcDialogToolTips
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/AcDialogToolTips.DLL
AcDialogTooltips.resources
Base di codice: file:///C:/Program%20Files/AutoCAD%20LT%202010/it-IT/AcDialogToolTips.resources.DLL
System.Drawing.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing.resources/2.0.0.0_it_b03f5f7f11d50a3a/System.Drawing.resources.dll
System.Windows.Forms.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
PresentationFramework.Luna
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
************** Debug JIT **************
di Windows Form. Per ulteriori informazioni, contattare l'autore
dell'applicazione.
AutoCAD LT 2010 is not supported to run on Windows 10, either update your AutoCAD LT or make the step back to your original operating system.
Details from Autodesk about their products on Windows 10 >>>click<<<
- alfred -
Strange, because I am using windows 10 with autocad LT2010 from this summer and today is the first time that appear this problem...
Then you are one of the lucky ones, at least for a few months.
So when it was running well and now stopped then look what happend to your system, most probably some updates where installed (or any other software)?
- alfred -
public static Bitmap GetBlockImage(this ObjectId objectId, Size size)
if (!objectId.IsValid())
throw new InvalidDataException(nameof (objectId));
if (size.IsEmpty)
throw new InvalidDataException(nameof (size));
Autodesk.AutoCAD.Colors.Color backgroundColor = Autodesk.AutoCAD.Colors.Color.FromRgb((byte) 0, (byte) 0, (byte) 0);
return System.Drawing.Image.FromHbitmap(Utils.GetBlockImage(objectId, size.Width, size.Height, backgroundColor));
I also encountered this type of error, what should I do? I am currently using the English version of autocad 2018. I remembered before that it seemed that it was not difficult to get the preview of the block reference, but now I don't know what I forgot, and it keeps throwing this error message.
Can you take a look at it for me? Thank you very much. In order to more clearly restore the current dilemma, I will show more code.
var doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var locadCADPath = "test.dwg";
var locadDB = new Database(false, false);
try
var tempName = string.Empty;
locadDB.ReadDwgFile(locadCADPath, FileOpenMode.OpenTryForReadShare, true, null);
locadDB.CloseInput(true);
using (var trans = locadDB.TransactionManager.StartTransaction())
var bt = trans.GetObject(locadDB.BlockTableId, OpenMode.ForRead) as BlockTable;
var ids = new ObjectIdCollection();
foreach (var btrId in bt)
var btr = trans.GetObject(btrId, OpenMode.ForRead) as BlockTableRecord;
if (!btr.IsLayout && !btr.IsAnonymous)
tempName = btr.Name;
var targetID = btr.ObjectId;
var image1 = targetID.GetBlockImage(new Size(60, 60));
image1.Save("image1.jpg");
var image2 = targetID.GetBlockImage(new Size(200, 200));
image2.Save("image2.jpg");
var image3 = targetID.GetBlockImage(new Size(500, 500));
image3.Save("image3.jpg");
ids.Add(targetID);
break;
locadDB.WblockCloneObjects(ids, db.BlockTableId, new IdMapping(), DuplicateRecordCloning.Ignore, false);
trans.Commit();
locadDB.Dispose();
System.Runtime.InteropServices.ExternalException: 'A generic error occurred in GDI+.'
This exception was originally thrown at this call stack:
System.Drawing.Image.FromHbitmap(System.IntPtr, System.IntPtr)
System.Drawing.Image.FromHbitmap(System.IntPtr)
DrawingMaster.XrefBlock.InternalNamespaceTool.GetBlockImage(Autodesk.AutoCAD.DatabaseServices.ObjectId, int, int, Autodesk.AutoCAD.Colors.Color) in BlockCommand.cs
DrawingMaster.XrefBlock.BlockCommand.Run() in BlockCommand.cs
The reason I encountered: it is necessary to determine the blank blocks and filter them out, otherwise an error will occur.
https://forums.autodesk.com/t5/net/a-generic-error-has-occurred-in-gdi/m-p/12727098#M81789
