QuickSelect points by attribute (Code)
Hello. I want to know if there is a way in autocad to quick select points by one of their attribute values (Such as Code).
In the picture below I hope you will understand what I want to select.
cadffm
Program extension or just command FIND, check the available options there.
Sebastian
If i use the FIND function it only selects the Text whilst i need the point with the attribute IP to be selected
ChicagoLooper
If you want to select all blocks where the attribute COD = IP I don't know a way in Vanilla AutoCAD. You can however, successfully do it in Map 3D by running a query which would focus on an attribute of your choice and isolate, or select, only those blocks where there attribute equals IP.
The closest operation in Vanilla AutoCAD would be DATAEXTRACTON command where you run a wizard on the properties of blocks in your drawing and end up with a spreadsheet. The wizard has 8 windows, or pages, and at the end, you can end up with a spreadsheet with columns. The spreadsheet could easily be customized to include properties such as: Block name, x-position, y-position, DENPCT, COTA, COD, layer.
Chicagolooper
dbroad
Since it appears that each point object that you want to select is near 2 other objects which may be unrelated by layer or color or time of position within the database, it would seem only possible to do with a custom program that would make a collection of text with the attributes desired and then scan for points near those attributes with the hope that the closest point would relate to that attribute.
If you want to continue using AutoCAD rather than Map, I suggest building blocks that truly have attributes along with the other geometry. Then dataextraction is easy and can be filtered.  Building a custom program to filter blocks by attribute values and return a selection set would be trivial compared to your current task.
Architect, Registered NC, VA, SC, & GA.
connordaly2001
Community Visitor
Community Visitor
  • ENTER 'FIND' COMMAND
  • UNDER THE 'FIND WHAT' LINE, ENTER YOUR ATRIBUTE NAME (E.G. IP)
  • SELECT THE 'LIST RESULTS TICK BOX'
  • CLICK THE EXTEND WIDOW ARROW AT THE BOTTOM OF THE WINDOW
  • UNDER THE 'TEXT TYPES SECTION' SELECT ' BLOCK ATRIBULTE VALUE'
  • IN THE SEARCH OPTIONS I LIKE TO KEEP 'SEARCH BLOCKS' AND SEACH 'XREFS' TICKED
  • CLICK 'FIND' AND A LIST OF YOUR FILTERS POINTS WILL APPEAR
  • AT THE SIDE OF THE WIDOW SELECT 'CREATE SELECTION SET (ALL)'
HOPE THIS HELPS  : )
annamariapapoutsi
Observer
Observer
THIS IS HELPUL!
BUT WHEN YOU FIND THE POINTS YOU WANT HOW DO YOU COPY OR CUT THEM ?
I ASK BECAUSE WHEN I SELECT THEM FROM 'CREATE SELECTION SET (ALL)' IT SELECTS ONLY THE DECRIPTIONS BUT NOT THE POINTS.
