quick select show empty properties
Hello bros,
I'm using CAD 2007 in windows 7, for 3 years.
But recently, when using command QSELECT or Quick Select
the field "properties" not showing any option for me to choose. (before was many option there)
it happens when i trying install CAD 2014, but pop out some error when install, i still can open CAD 2014 but it so slow, then i uninstall it.
when i reinstall CAD2007, command qselect not working like before.
Can someone help me fix this. Thanks !!!
ps: i also tried to repair, clean registry, uninstall all Autodesk products, reinstall...
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
I think it's not depending on installation of AutoCAD 2014, it might be depending on the drawing and if the drawing was created with AutoCAD 2014.
Try to start AutoCAD 2007, create a new drawing, draw a line and start again _QSELECT, I'm quite sure the the dialog shows the normal results.
When you say you have installed CAD 2014 ... which type of CAD do you mean, what the product name exactly?
The question has a reason, if you have created a dwg-file from a newer AutoCAD and you used some objects from vertical products then you will have proxy-objects in the drawing and they can't show properties and that might be the reason why the property area of the _QSELECT dialog is emptry. To verify that start again AutoCAD 2007 with your drawing, start again command _QSELECT and open the list "object type" ... do you see "proxy object" (or something similar) listed?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
qnologi
tuongduy25o21 wrote: ps: i also tried to repair, clean registry, uninstall all Autodesk products, reinstall...
1. Have you checked "PICKADD" set it to (1)
2. Have you tried to "repair" the installation?
3. Are you up to date on all Service Packs and Updates?
4. At what time did you "clean the registry", before or after the reinstall?
I've heard a lot of "bad" things about registry cleaners and AutoCAD, my opinion, of course...
Perhaps someone else will chime in with more info.
qnologi
