Quick select a layer to draw
dvrVSNMW
Message 1 of 9
dvrVSNMW
I use 5 different layers a lot.
Now I always need to go search for the correct layer to use in the dropdown layer menu.
But can I add a button to my screen for the most used layers? So I can click these buttons so I have instant the correct layer?
Or can I add a layer type to a keyboard key ?
Regrads,
DVR.
Replies (8)
Message 2 of 9
makdezines
Use Laycur command
Message 3 of 9
illusionistNUGXG
You can change the active Layer with the CLAYER command.
To use it with a button in the ribbon or keyboard-shortcut, you need a macro.
Example:
^C^C_CLAYER;0;
This changes the active layer to 0.
If you have more than just numbers as layernames, you need to put the layername in quotations. Example (i have AM_-layers for using AutoCAD Mechanical...therefore...)
^C^C_CLAYER;"AM_4";
This changes the active layer to AM_4.
The macro can be assigned in the CUI (customer user interface).
There in the bottom-left block you can create a new command, rename it and put in the macro with the desired layername.
To use it as keyboard-shortcut:
Now in the list of the top-left block, expand the part named Keyboard....uhm...something (-shortcut commands?). Below this should now be "Keyboard shortcuts". Drag and drop the new command from the bottom-left block to here.
Now at the right side of the menu, you can assign a keyboard-shortcut. (use the [...]-box at the right)
Assigning it to a button to the ribbon is also possible in the CUI, but that's out of my experience.
Oh, by the way...it only works, if the layer is already a part of the drawing. If the layer isn't in the drawing (just activated once - no lines have to be used), it returns an error message.
Message 4 of 9
Kent1Cooper
@makdezines wrote:
Use Laycur command
I think you mean LAYMCUR.  LAYCUR puts selected objects on the current Layer [it does not change the current Layer]; LAYMCUR makes the Layer of a selected object current.  But LAYMCUR requires having an object drawn on that Layer to select, which you might not always have, or not in the current view.
I would suggest macro items in a Tool Palette, as already suggested by @illusionistNUGXG , but with a difference.  The Layer command can be transparent, meaning you can use it in the middle of another command if you have reason to.  [I'm not sure what such a reason might be in the case of LAYER, but there could be some.]  In order to allow that possibility, you can't have the common ^C^C [two Cancels] at the beginning of the macro, and you must use '-LAYER with the apostrophe prefix for transparent use and the hyphen to prevent the dialog box.  Macros like these:
'_.-LAYER _Set YourLayer1 ;
'_.-LAYER _Set YourLayer2 ;
'_.-LAYER _Set YourLayer3 ;
In case the Layer in question may not exist in the drawing, you can use the _Make option instead of _Set, which will also make it current, and which won't have any problem if the Layer does already exist:
'_.-LAYER _Make YourLayer1 ;
'_.-LAYER _Make YourLayer2 ;
'_.-LAYER _Make YourLayer3 ;
[The underscores make them work in AutoCAD for any language, and the periods make them use the native command in case there may have been a revised definition of it.]
Kent Cooper, AIA
Message 5 of 9
dvrVSNMW
Thx for the reply's.
I never made a macro. Can u pls help me on this ?
I came this far:
https://ibb.co/nP631hT
But where do I enter the command I want to use? And what type of commands should I use to keep it simple? Like l1, l2, l3, l4,... ?
Are the things I have done already correct ?
Message 6 of 9
Kent1Cooper
@dvrVSNMW wrote:
....I never made a macro. .... where do I enter the command I want to use? And what type of commands should I use ... Like l1, l2, l3, l4,... ?
From your original message, "...can I add a button to my screen for the most used layers? So I can click these buttons so I have instant the correct layer?" suggests a Tool Palette, in which there would be "buttons" to click on.  Those would contain code as in my previous Reply, and would not require giving a command name to each -- you would just click on the buttons.  But if you want to have command names that you can type in, that's a little different.  They could also be done with keyboard shortcuts [Ctrl+something, Alt+whatever, etc.].  Do you have a preferred method?
Kent Cooper, AIA
Message 7 of 9
dvrVSNMW
I was simply thinking of naming it lay1, lay2, lay3,...
i'll try making buttons as well. Keep u updatet.
Message 8 of 9
ВeekeeCZ
@dvrVSNMW wrote:
... Or can I add a layer type to a keyboard key ? ...
Yes, this is a built-in feature, see HERE  how it works.
I recommend turning off all other content but layers -- just to make the search list as clean as possible from items you don't use.
Message 9 of 9
RobDraw
You can also use objects to set the current layer:
Make Object’s Layer Current (LAYMCUR)
Using this tool will change the current layer by selecting an object as reference.
There's a button for it, too.
Rob
