Question about a %% code
labtechjc
labtechjc
I have a drawing that is showing a "?" for a symbol.  I have no idea what the symbol is, but when I look at the properties for the "?", it says the text is %%146.  Then I have another "?" that has the properties of %%141.  Does anyone know what symbol those codes are pointing to?  I can't seem to find what it is.  All I can say on it is the complete line of text is RF ?, ? IN/OUT.  First "?" is %%146, second is %%141.
Patchy
Could be fraction, %%141 is for 7/16  and %%146 is 1/32
if you use FRACTION.shx
Valentin_CAD
@labechjc ,
Is this an AutoCAD Plant 3D or AutoCAD Electrical drawing?
Since it contains RF, and IN/OUT  - it could represent numbers.
If the code is meant to be a symbol, then it could be some ASCII Character Code like those in these links:
Similar to what AutoCAD uses for Symbols and Special Characters:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
rkmcswain
Those are codes pointing to a particular character in a particular shape based font, IMO.
So if you don't have the right font, or you have a substituted font that does not contain those characters, you get "?"
labtechjc
Looks like the RF relates to Radio Frequency.
labtechjc
Got lucky.  Someone was able to find a picture version of the file that had the correct symbols on it.  Managed to figure it out from there.  %%146 was Σ and %%141 was Δ.  Thanks for you help.  Good to know that those do equal something in case it pops up elsewhere!
