Query AutoCAD
Query AutoCAD
NICOLENUNAG13
Query AutoCAD
NICOLENUNAG13
How can i save or transfer my own edited aliases into a new AutoCAD. Many thanks.
Alfred.NESWADBA
Are you speaking about AutoCAD Map 3D (or Civil 3D)?
Because "Query AutoCAD" is not a function from AutoCAD (which is handled in this forum), and "aliases" has a different meaning in Map 3D for queries (where you have paths saved) compared to "aliases" in AutoCAD which is part of shortcuts for commands (most handled in ACAD.PGP).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Alfred.NESWADBA
In the meantime (guessing you mean Map 3D / Civil 3D command _ADEDRAWINGS ==> assign) you can search for the file "acadmap.ini" for your current Map 3D / Civil 3D program data path, like
C:\ProgramData\Autodesk\C3D 2025\acadmap.ini
(for Civil 3D 2025)
There you'll find (using a text editor) the defined alias definitions, which can then be copied to the file "acadmap.ini" for your new Map 3D / Civil 3D version.
HTH, - alfred -
Alfred NESWADBA
NICOLENUNAG13
Sorry for the confusion. It is basic AutoCAD.
j.palmeL29YX
In your current AutoCAD type in the command line:
Command: (findfile "acad.pgp")
You will get a result similar to this:
"C:\\Users\\jupa\\AppData\\Roaming\\Autodesk\\AutoCAD 2026\\R25.1\\enu\\support\\acad.pgp"
Copy this acad.pgp file into the appropriate path of your new AutoCAD.
Jürgen Palme
