QSAVE instead of QUICKPROPERTIES
In other versions of autocad, the shortcut for QSAVE was just the letter "Q" and pressing intro, my problem now is that when I type the letter "Q" and press enter, autocad adds automatically the letter P and enables the command QUICKPROPERTIES instead.
(As far as I know Auto cad chooses the option that you use more frequently, but I don't know how to set it to QSAVE)
What can I do? if I type "QS" the problem its solved, but I'm really used to only enter one letter.
Thanks a Lot!
ennujozlagam
you can add keyboard shortcuts just go to express tools > command aliases > you can add new shortcuts thereshort.JPG. thanks
imadHabash
>> What can I do?
from ALIASEDIT command check from the Command Aliases tab if the Q letter alias is exist for Qsave command . if it's not there , press Add or Edit buttons to make it .
if it was exist in your command line and now it's not available , i think that there is something new happened in your machine like resetting AutoCAD for default settings or similar . and AutoCAD usually display in the command line the most often commands the you used . >> Click <<
Imad Habash
j.palmeL29YX
Disable the AutoComplete (remove the check mark).
Jürgen Palme
