you can set in _OPTIONS ==> Files ==> Templates your folder with your templates.
You can define that folder and into that folder copy the DWT-files you like to have to select.
You can then use command _NEW (not _QNEW) to get a dialog to select your preferred template.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
