PUBLISHING TEMPLATE
- Mute
- Permalink
- Report
Hi guys, I have made a template drawing (.dwg) titled "1 to 100" which had 50 sheets setup so that I can publish up to 50 drawings in my model space quickly and easily. I saved the sheet list in a particular place and have to import it every time I want to publish. I then copied the template drawing (.dwg) and renamed it to a specific job name "5460_SS_1-PLANS - NEW" and then tried to publish but when I imported the same sheet list I realised that the sheets still refer back to the "1 to 100" drawing which meant that all of the pdf drawings still did not come from the "5460_SS_1-PLANS - NEW" drawing. How can I import the sheet list and quickly update the source drawing so that all of the sheets are still in the same place but come from the renamed dwg instead of the template drawing. It is very time consuming to redefine the sheets with every new drawing.
