Publishing an older version of the drawing.
This widget could not be displayed.
I'm using 2019 LT and publish a lot of drawings. Today I saw something that I don't believe I've seen before. I started working on an existing drawing, copied the existing work in model space and modified what I needed and setup paper space to display the modified drawing. When I went to publish the new drawing, the original drawing was shown. I tried again with the same result. I finally deleted the original drawing from model space and purged. I published again with the same result. As a last attempt, I copied the modified drawing into a different CAD file and published, same result. The top image below is my modified drawing. The bottom one is what is shown when I publish. I asked a co-worker to confirm I wasn't doing anything wrong or for some ideas, but he didn't have anything to offer.
M-Alam
Check to see if the modified work is on a defpoints layer or non printing layer
That solved it! Thanks!
