I use Publish in Autocad C3D 2016; then I select a DSD to back up my settings:
"Do you want to save the current list of sheets ?" -> click no
Select a DSD
click on "replace all sheets"
then click on "publish"
Everything works fine.
Now I want to use this same routine in a script so I use "-publish" instead of "publish"
-publish
S:\dossiers\9195 Beernem Oostveld afkoppelingen\Tekenbureau\4a OF 2\9195 Huisaansluitingen\afkplannen\9195 18.dsd
Now I get the message
Job: - Error(s) Did Not Plot
Job ID: 7
Sheet set name:
Date and time started: 15/10/2015 14:12:28
Date and time completed: 15/10/2015 14:12:28
UserID: Robbe
Profile ID: <<C3D_BE>>
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Number of warnings: 0
Sheet: afk2 - Error(s) Did Not Plot
File: S:\dossiers\9195 Beernem Oostveld afkoppelingen\Tekenbureau\4a OF 2\9195 Huisaansluitingen\9195 Ontwerpen - Nieuwenhovestraat.dwg
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
ERROR: Device not found
Is this a bug ? It's the same DSD.
In answer to previous posts: i do have the "dwg to pdf.pc3" on my printer list.
